...and I'm not Kockin "Cumminalong" but a Straight 6 compared to a V8 is a Totally Different Comparison.
Engine configuration makes ZERO difference to an exhaust pipe. After your exhaust goes into the pedestal and spins the turbo, how many places does it exit the turbo? 1. After mine goes into the turbo and exits, how many places does it come out? 1.
Pipe is pipe, there is only so many ways to make, bend or shape it.
Engine volume and total CFM are what dictate exhaust size. I don't care if it's a 12L truck engine or a 2L 4 cylinder, an engine must move a given amount of air. That's all it is, an air pump.
That air pump is only as efficient as the smallest restriction. If that restriction is right at the turbine discharge, the rest of the system has no impact, unless there is more of a restriction farther down stream (i.e. a muffler)
Perfect example is a funnel. Take a gallon of water in a bucket and pour it out....it dumps right out. Pour that same gallon of water into a funnel....what happens? It slows down because it has to go through the restriction. Take that same funnel and attach a 4" diameter hose at the end and pour the water into it......Did the water pass through the funnel any faster? Nope.
Same concept with your exhaust. If you make a restriction, the only way to move the same volume through the smaller opening is to increase pressure (i.e. back pressure).
Figuring out the RPM range, total CFM, expected exhaust temperature is how you figure out what size piping you need.
And no, my truck is FAR from stock. What is on my truck is sized for the anticipated air flow requirements.
On a stock 5.9, a full 4" exhaust works for 3/4 of the RPM range, but at the top (even on a stock truck) it's at it limits. Increase the size of the engine (i.e. 6.6L) or increase the turbo size to a 66 or larger and you're far exceeding what a even a full 4" system can handle on the top end.
Bottom line is you can make A SECTION of an exhaust larger, but if a previous section is smaller, it's of no benefit. Unless you can get rid of that restriction in the top of that pipe, adding a 4" exhaust is pointless. The best thing to get rid of is the muffler.
Could this go on and on? Absolutely. The only way to see what it really does is to do a before and after dyno. I think you'll be highly dissapointed in what you get for that amount of money.
