Removing shift boot?
bfourman
Member
Vincennes, IN
96 K2500 NV4500.
The PO of my truck replaced the clutch, but either forgot or didn't want to put the boot gasket back in. As a result, I get a lot of road and engine noise coming up from the boot.
It is just a matter of pulling it up from the floor, or is it fastened down somehow? Just wanted to make sure before tearing it up.
96 K2500 NV4500.
theres a metal ring that goes around it that is screwd down and then there are screws in the boot its self if i remember correctly the shifter should unscrew to make things some what easier
Josh is correct. There are 4 screws (one in each corner) of the metal trim ring, and then 4 more between them on the boot itself.
Got it, thanks. Ordered a new gasket from the local dealer; $8. PO only had 2 screws holding the boot down anyway, kind of glad I had to pull it up.
Just an update to this thread. The original gasket I ordered from the dealer was listed incorrectly in their lookup. The correct part number is 15024604 and was $20.74 wholesale cost. IIRC they list it as an "isolator".
The noise difference in the cab is amazing, definitely worth the $20 and 1/2 hour of my time.
It really does doesn't it? There was a night and day difference when i installed mine.
Glad you got it together :thumbsup:
Yeah, it's amazing. I installed a 3" straight pipe exhaust at the same time the truck was in the shop; it's quieter now even with the louder exhaust.
