Rodd
Recruit
What Racor filter models work best on our 6.5's? I've been trying to find a 490 like matt's but have been unable to find any at a decent price. I was just wondering if others models worked just as well.
There was a reasonable vendor on e-bay iirc.
I knew you would have a plethora of information. Basically what you are saying is If I get any 400 series I can use any of the aforementioned sized filters.445, 460, are sufficient for most, I have a 460 on the truck & a 490 waiting to be installed on the burb, all use same head just longer filter body for 45-60-90 gph, I got the 90 because of the price not that I'll be flowing 90gph. The 4 indicates with prime 645 is a non priming head, 45, 60, 90 indicate the gph, R-S-T indicate 2-10-30 micron I think; it's been a while since i've looked up the letter designator. I run with a 10 micron on mine
Right. The filters for each series are interchangeable, both for size (45/60/90) and for micron rating (R/S/T). Right now on eBay, there's an older style 500-series with an integral heater. Pretty reasonable. I also saw a Racor add-on heater kit . Kinda pricey; cheaper to buy the entire setup from the git-go. I'm going to buy one of the 500's and install it on the frame before the fuel pump. That way the pump only sees heated, filtered fuel. No problems from gelling or clouding fuel.I knew you would have a plethora of information. Basically what you are saying is If I get any 400 series I can use any of the aforementioned sized filters.
Not certain what mounting locations you're considering, or where are good spots on a Suburban?
Nice install! The bed is off my truck right now, so now would be a good time to do bracket work on a crossmember. I also like SD's idea of a shield to protect the filter from road debris. Hmmmm.... Projects for Thanksgiving!I put a Racor R45P inline before the lift pump, mounted on a crossmember.
Can't beat this guy for Racor.
Staff edit ebay link removed, this ebay vendor is a direct competition with vendors that pay to advertise their Racor filters here
Just make sure you visualize the size of these things, they are huge.
I love mine. The clear bowl is awesome. Not only can you see fuel condition, but all sorts of rust/other things heavier than diesel end up in there...
Are all of Racor's filters capable of H2O separation as well? Or do you have to buy a completely different one?
Hey I like this form of editing beats no explanation
Racor and Wix elements are treated with chemical "Aqua block" that separated water, same stuff that is supposed to be on the on engine OEM style filter.Are all of Racor's filters capable of H2O separation as well? Or do you have to buy a completely different one?
