treegump
Romans 3:22-24
When I got my front end aligned and the new pitman arm installed, I asked the mechanic to find out what I had as far as the drivetrain went. Everything is behind the 6.5 - so I don't know if that makes any difference. I gave him all the choices that my Chilton's manual gave and he picked the following:
Tranny - T-5 Muncie (MW3-New Venture 2418(?) New Venture) (I briefly looked up the combination T-5 Muncie and from what I read the T-5 is weak and not interchangeable with a Muncie...) I do have a 5 speed manual - so would this really be a NVG4500?
Transfer Case - 241/243
Differential Rear - 10 1/2 (I have the 13" brakes, and the parts I've asked for so far have matched up, so I believe this is right)
4/10 (he has an arrow coming from the transfer case...is there a gear ratio for the transfer case?)
Any help or clarification would be nice...I would like to change my tranny and transfer case fluid and don't want to put the wrong thing in. Thanks!
VIN is 1GCGK29F6TE10001 - if that helps any
