Any Cracked Piston members here?
BoostN
Staff member
Administrator
Tennessee
After all you hear about the LBZ pistons. I was curious if we had any members that have been a victim?
I'm at 50K now, and still running strong. My truck has been tuned since 3,000 miles. I'm setting around ~425 or less RWHP.
Maybe it'll hold out so I can get my trans build. Then, I guess I'll be saving the nickels for a build motor..:doh:
I do think I'm going try to be a member..:D
Does this only happen with a programmer turned up high or does it happen being all stock or just a tow tune? My dad is looking into getting an LBZ. He'll probably leave it stock but I might be able to talk him into a programmer.
For the most part it is happening to trucks that are over 500 Hp. Some have done it with less and some for some reason stay together. A programmer should no problem at all.
I dont think theres any rhyme or reason for it. I have heard RUMORS of stock trucks cracking ( no personal proof) and others from as little as a tow tune to high HP tunes cracking. I personally have been at over 500 hp for 45K miles with a total of just over 69K on the truck. I must have gotten a good motor lol
Hmm, so the dealers are probably denying warranties on the programmed trucks?
My dad would be pretty pissed if I talked him into a programmer and then he cracked a piston!
They try to deny warranty any and every way they can. With that saying, it really depends on the dealer your using. Some are more lenient than others.
We have a pretty good dealer sales and body shop wise...not sure how they are about warranty work since we've never had too many serious issues to deal with.
From what i have seen, high timing +35*, ecessive egt's, and low boost have been putting holes in the piston. Im at 26K and havent had a problem
How is thing's going now with them dual DPF's?? :D
Off a little
Your off just a little on your guess of 425HP, you can add about 100 HP to that.:thumbsup: But we see at Suncoast 2010, if we make it.
Yea, I'm defiantly over 500 now with Rob's tuning.
