Indy MGW got to this before I could respond to your PM request:
As MGW has indicated so long as the gears were not removed the timing can not be off, IP only goes in 1 way, the pin on the IP fits in the long slot.
For the (3) timing gear bolts I break torque and back out bolt a few threads so I know it's going to be easy to move, then I use my "mechanical fingers/grabbers" on the bolt head, reaching into the front timing cover to spin out the bolts a rag into the hole is also a good precaution as well just in case the bolt head pops out of the "fingers". I have done it this way multiple times with success.
For a mechanical "ballpark" timing reference center punch or chisel mark the IP & back of the timing cover to get the current timing, which unless somebody before you has done a TDCO advance movement should have the IP positioned to factory spec of -.25 to -.75 TDCO.
So for the new replacement IP you can measure the distance of the punch/chisel mark you made on the old IP to a reference point on the old IP, then match the same distance on the new IP to same reference point which would be as close one could be with a non scan tool "field setting" you could make.
Now if you get to an engine/IP that has never had a timing punch mark made to it and old IP is already out, way that has worked for me in "field setting" of an IP is to install the IP with the fuel shutdown solenoid pointed to a 12 o'clock-ish orientation. Then I snug the bottom (2) IP lock nuts so I have some resistance to rotating the IP but still have ability to move it with effort.
Plumb in the IP lines, electrical connectors, intake, & other removed parts, with the IP still in the 12 o'clock orientation, fully tighten the top IP mounting nut, crank to purge the IP and maybe even start if it will go, if it doesn't start after adequate purging, loosen the top IP lock nut and rotate towards driver side (advance-time) and that should get you to a point of being able to have successive starting so you can find somebody with a scan tool to get "spot on" timing set point.
