kane
We had a  "Dynoday" today, got acceptable results 193kW and 615Nm (0.8bar boost) http://kuvablogi.com/nayta/2322101/ :smile5: Printed RPM readings are not correct.
I have the stock turbo (1994 = GM4?), homemade turbomaster ~0.8 bar pressure. And chip from kojo, fuel table is more agressive from the lower pedal % position but modified so that there's not too sensitive on/off feature when driving with "light pedal" (I believe it's same that you have tested). Anyway, max fuel is 80mm3.
I also have DIY fsd resistor with value 110K Ohm, I have no idea if it's really improvement than res#9 but PCM does not give any error DTC :smile5: :rolleyes5:
What kind of flexible hose did you use for your intercooler.
Nice. yes I am testing the same chip, you are running. I like it a lot, DID KOJO dyno his rig as well?
