iamdave0887
Here Comes Chaos.....
Ok guys. something strange is going on.
My blazer seems to have jammed up the starter. Just to make a not this is the old direct drive starter, not the gear reduction starter. If i rotate the engine back i can hear the starter drive gear go "click" and retract into the starter. If i turn the key all i get is a loud "click!" and then all the lights go to about 1/4 brightness and i can hear a high pitched hum/buzz of the starter trying to turn. If i put my hand on the starter afterwords it is quite warm.
The engine turns over via breaker bar on the balancer pulley bolt just fine so it's not hydro-locked.
Different batteries change nothing(i put two brand new ones in). All connections are tight. Starter cable is the size of a garden hose at 4/0. crossover is 2/0 and both main battery grounds are 2 awg.
The truck started just fine before. Could i have busted my starter somehow? This never happened with the 700R4 in the truck, only with the SM465. I have no inspection plate on the trans and it seems the starter nose cone is not supported as the starter opening is quite large(i find this strange) The starter brace is attached at both the starter and the block, and both starter bolts were torqued to 40 ft lbs when i installed the starter last week.
Please help me. I do not want to put in my gear reduction spare if it's going to get damaged. I"m planning on pulling out the starter tomorrow to check for damage. I looked at the flywheel teeth and none seem to be damaged at all.
Could the starter need to be shimmed?
