turbovanman
I has boost, :O)
Do I have to do anything to it, IE turn it up or will it be fine as it. Will be running a remote mount stock GM turbo.
Also, how can I set the timing on it?
The military Hummers run a 24 volt electrical system. You will need a 12 volt FSS.
When do we see pics.
Pensacola has the best prices. I think they quoted me around 300 for a 6.2 DB2 but you may want to consider the DB2 used on the 93 6.5s. Thnk they pump a little more fuel. Slightly bigger plungers.
I'm curiuos to see how the Holset works out for you. I have been eye balling the same thing but with a Banks ex manifold instead.
The 4911 pumps from the 92-93 6.5's have .310" plungers and will push far more fuel.
Stock 4911 will work great in factory trim on a turbo 6.2
Missy
