The mechanical wastegate actuators are very popular, and a lot of guys like them.
As you may know, the wastegate is the 'valve' which permits the total boost pressure on a turbocharger to be controlled. In the 6.5, it was designed to be controlled by computer, with independent control of the boost. This is theoretically superior, because it allows you to boost the pressure when needed for performance, but to back off on boost when you don't need it, thus reducing pressure and wear on the engine.
The problem is that GM's strategy was to use a vacuum-controlled wastegate, and has had reliability problems, with the vacuum pump, vacuum tubing, and solenoids, all of which are prone to failures.
The reason why people go to a mechanical wastegate controller (which simply uses a spring which releases when the mechanical pressure on the spring exceeds its preset limit) is that people report that the boost pressure is more consistent and predictable. Others say that if you have a good, operating vacuum system, that you can get a ECU which gives more aggressive boost when properly programmed.
My opinion is that the manual wastegate controllers are by definition more reliable since they have fewer parts and complexity. However, if your goal is ultimate control of boost under all conditions, then theoretically the best method is some kind of system which is independent from other contributing factors, such as engine speed, etc. Therefore, the vacuum system is theoretically better for independent control of boost. The problem is that I don't think that ECUs have really been programmed to operate with the stock system as a cohesive unit. In other words, the best ECUs (Heath?) don't advertise that they have been programmed for use with the stock system. The marketing materials say to me that they work OK with the stock system, but they really recommend that you go with a manual control. They don't explain WHY. Because to me, you should be able to use the factory system to get just as high a boost as with the manual controllers, and you could also automatically back off on boost if it is getting too high, since you have a sensor for boost pressure in the system.
I do agree this doesn't have a definitive answer.
-Rob
