Hey TD, I would say it would actualy be easier to install the FPT (fuel pressure tap) (and cleaner)
With my design you still keep the air bleed function. It has an oring seal on the bottom. Just hand tighten the FPT, when you want to bleed the air for priming the filter just loosen the FPT and air will escape until fuel comes out. One benifit of using the FPT is a person could plumb in a tee and a ball valve to direct the fuel (when bleeding) somewhere other than all over there engine and down the engine valley. Same reason my filter is now off engine easier filter change, no fuel on engine,
I work on and with filters everyday and think both prefilter and post filter pressures can be very informative. So do I, and if going with just one gage you need to monitor the filter outlet IMO not it's inlet
Prefilter: if the pressures go up from normal that is a sign the filter is getting dirty.
if you had a non regulating pump, but remember on the 6.5 lift pump it will cut off on high pressure from a blocked filter and why you need to monitor the supply side to the IP for pressure discrepancy, as that is the end user of the fuel so that would IMO be the best most remote pressure monitor need, sort of like a most remote bearing monitor in a gear train, if it has oil one can assume rest of the system probably has oil
If it goes down it could be an obstruction before the LP like a snotty sock, the LP is going bad or possibly a leak between the LP and FPT.
The best would be to monitor both pre/post filter and see the differential.
Vac switch works better IMO if going single sensor I have 2 vac switches but only need the one since high vac at outlet of filter mgr/IP inlet lets me know something in system is wrong, including clogged sock
This is not the hard way. Literaly a 2 minute job (for just the FPT). No drilling, taping removing parts off the engine.....ect
