I have always thought that the "addiction" part was from a result of slightly bent connecting rods from the use of ether, resulting in lower compression and difficulty starting after wards. Another shot of ether and it will start again resulting in an "etherhead " engine. I also have a tractor with an ether port on it, but it does not have 400 psi of compression either. so I guess it depends on the breed of diesel. I never use it myself--
Same here. Exact same reason I heard. Then again, once a fleet truck gets 'started cold' with ether, why bother to fix the glows? 'Just use ether'... It makes the engine race, before oil pressure can even build, not to mention its extremely dry.
I don't even own a can of ether. I do have an old can of starting fluid for my old bone sander engine though. Its rusting out (the can)... I would never even use it as 'last resort' on my truck. Its not like if its not starting on its own, a shot of ether will make it run.
It may make it run until the ether is all used up, but then the orignal symptom of failure is back (fuel?)
Maybe I'm just so use to a fully functioning glow system, that I'm spoiled by my trucks ability to start at all temps. Like I formentioned, started 8df overnight outside unplugged with no compresssion in one cylinder. FIred right up.
I would be extremely pissed off at a mechanic if they said, "It ran off the ether, but then died"...
I am not pissed off if friends of mine like Bison want to use it on his truck.
I have used it on older fords 6.9's, at the tow garage I use to work at. I've even diagnosed other peoples vehicles for no fuel by saying "IT ran off starting fluid"...
Maybe its good old forum parania striking again !! LOL.
Perhaps I shouldn't be commenting, as I have no real-life experience with Ether and 6.5's, and I never plan to have any.
But I can't resist... I'm addicted to DTR, and apparantly I'm a....
ostho
But it's better than being a...
:dr:
