Ok thanks for the info. This is my first truck and I've only had it a year. The previous owner had the torsion bars turned up as far as they could go, but I had them turned down a little bit so I don't know if 2" is the true amount. I have 285's on right now.
I'm just getting crazy fast wear on the outside shoulder of my front right tire, as well as accelerated wear on the drivers outside shoulder, but the pax side is really bad. There is also a slight pull to the right, and even after multiple allignments it always seems to come back. Pitman and Idler arm's were both replaced less than 20k miles ago.
I'm not too knowledgable with what all happens when you lift trucks. I know a lift kit is the best way to go, but I can't afford one right now. And I only need what I have now, I don't need anything bigger than 285's. Most kits I see start at 4", but I only really need 2" to fit 285's.
Apparently Norcal now makes an Idler/pitman brace for our trucks, just like the ones for the dmax's.
But maybe it's my tie rod's that are wearing??
I just have trouble picturing what all happens when you lift it the way mine is. All I can picture is that the lower control arm is now really close to the bottom stop, so there is very little room for it to move down before hitting the stop. Can't picture what is happening to the drag link or anything else.
