Finally got the trailer on for some light duty runs. Trailer empty is 7500 and I guessed the truck with me, Diana, and less than half tank was about 7k.
Interesting run for me as I'm a bit of a mpg nut so I keep it in as high a gear as I can to get the job done.
IAT at cruise on I-5 were about perfect for my style. It was in the 70s here in Portland Oregon during my run and IAT was 150 +/- 20. I tried and forced it to as high as 220 on the short hills I have locally. (For MissyGW, Rat, TT, and you other Portlanders--> I-5 from Willsonville to the top of the Terwillerger curves, I dropped down to 32 mph in second gear for a bit on the steep part. Highest rpm/IAT I saw was 2900 & 220 on the ScanGauge). I don't think it ever defueled like it has in the past. I wasn't at high IAT long enough to trigger it. The ScanGauge was showing 99% load almost all the time so I believe the PCM is the next bottleneck in the power supply. It's due for a fuel filter, but, the Walbro never dropped below 4# on fuel pressure.
Boost just doesn't seem to build past 5 psi unless I'm north of 2300. By 2500 I can usually get to 10. These were just short runs on some local hills.
Mike
