If youre still running GM4 thats your problem, IATs skyrocket on a GM4 when boost hits 10psi. Verify it with GMTDScan while driving. Driving empty it doesnt effect my engine temp though, but I imagine it would if pulling. On hills, which is an everyday occurence, my boost will go to 10psi and up sustained (which is the reason your TM may now be causing), the EGTs will go from 400 to 900 post turbo in about 3 seconds. Mine is on the vacuum setup, but I never got 10psi sustained (let alone the 13psi sustained I get for several minutes now) until I got my Engh Motors power chip. I know Heath says theirs works best with TM, so maybe you werent getting same sustained boost on hills with Heath chip and vacuum setup that you would get with Heath Chip and TM.
Relevance is that an ATT will solve your problem, since the backpressure drop wont make so much heat transfer from EGT to IATs
