Dmax650tq
How much fluid does the rear diff hold on a 3.73 rear end?
Does anyone know what size ring gear this rear end has?
Thanks.
Thanks.
I drained almost 3 qts. out of it. The fluid didn't look bad or smell bad.
1) If you had that much from the factory I'm surprised. Usually it's 2-1/2 at best.
2) But did it smell like grape juice?
3) Good choice with the Mobil 1.
oh if the syn was burnt the whole neighborhood would have smelt it.
75W90 synthetic. Alot have used Mobil1 (I did) and many have gone with the factory "grape juice" (I did on my '05) but it's about $30/qt. You might check with Ashton (Wrecker) a vendor here for Amsoil products as well.what weight rearend oil do you put in the rearend and what is the best synthetic to run in the front and rear with what weights.
