I cant hardly believe you would need to fool the Barometer, but maybe it makes more power if you do. That is supposed to be the exact Barometric Pressure not fooled, as it gives the engine an idea of your elevation/atmospheric pressure, and how much actual boost you have because N/A would be at the atmospheric pressure, anything over that is the amount of boost.
Now if you fool it to make it think that atmospheric pressure was much higher than it is, then you might accomplish the exact same thing, because you would be subtracting this amount from the total pressure the boost sensor sees. However I dont think it is necessary, and could be degrading to performance.
The boost sensor is what causes the codes becuase your out of the stock ECM's boost schedule, more pressure than it would be telling the vacuum wastegate solenoid to be allowing.
I use an F chip on my S engine, and all I did was pull the vacuum hose off of the firewall Baro sensor.
