Water in Hydraulic system
Discussion in 'Tractors & Farming' started by 1994ch, Jul 2, 2017.
  1. 1994ch
    1994ch Active Member
    430
    212
    Dec 6, 2008
    South Carolina
    I have a friend with a Dingo that got water in the hydraulic tank. It uses 15W40 oil. We changed the oil and fixed the seal where the water got in, but I was wondering how many times he should change it again to flush out the lines and pistons. It holds about ten gallons, so finding the balance between saving the pump and spending $200 per oil change would be ideal.
  2. btfarm
    btfarm 330,000 Worth and counting Staff Member Moderator
    16,578
    2,331
    May 12, 2008
    Sandwich, Illinois
    I would change it once again if the seal fix holds.
  3. Will L.
    Will L. Well-Known Member
    7,406
    6,008
    Jan 25, 2013
    Boulder City Nv
    If you can: drain it out into metal container, no lid. Use drum heater or something (no open flames is best-duh) and Heat to 195 and the water will instantly separate from the oil. Pump off the oil from a few inches above the bottom to not get the water.
    You'll waste almost no oil and be good to go.
    tanman_2006 and Jaryd like this.
Share This Page
