Transfer case going into neutral without shifter movement
Discussion in 'Drivetrain' started by WarWagon, Apr 20, 2018.
  1. WarWagon
    WarWagon Well it hits on 7 of 8...
    8,246
    2,685
    Nov 15, 2009
    AZ
    After using 4 low and then going back into 2 high I have had it pop into neutral several times. The Shifter doesn't move from 2 high. No gear grinding even when I shove it to 4 high and back to get it back in gear. First time this has happened.
    I know the passenger side engine mount is shot. I do have a spare transfer case around. Anything I can check before swapping the T-Case?
    MrMarty51 likes this.
  2. Will L.
    Will L. Well-Known Member
    7,546
    6,311
    Jan 25, 2013
    Boulder City Nv
    Move it into position and disconnect linkage. Verify by feel of hand on transfer case control it feels all the way in position. Then see if it jumps out.
    Remembering the Alamo might not help you here, but a proper working parking brake will.
  3. THEFERMANATOR
    9,007
    2,370
    May 9, 2008
    ZEPHYRHILLS FL
    The nylons are broken off of the shift forks. Very common problem in older cases or ones that have been run low on oil.
    MrMarty51 and WarWagon like this.
  4. WarWagon
    8,246
    2,685
    Nov 15, 2009
    AZ
    Has 200k on it at least, not surprised if it's worn out. Don't recall if it was swapped with the trans for awhile or not. If not it has 1/4 mil miles.
    Park brake I use often, but, good point! @Will L.
  5. THEFERMANATOR
    9,007
    2,370
    May 9, 2008
    ZEPHYRHILLS FL
  6. NVW
    NVW Well-Known Member
    8,706
    1,325
    May 5, 2008
    Castor, AB.
    Jeeez, $5 part, $20 shipping to Canada.
  7. NVW
    8,706
    1,325
    May 5, 2008
    Castor, AB.
    For the heck of it I searched some more, found one with $65 shipping. Ferms link looks like a bargain nowo_O
    MrMarty51, Jaryd and WarWagon like this.
  8. Sand
    Sand Active Member
    188
    198
    Mar 27, 2016
    Canada
    I got mine online from american powertrain. The New chain was cheaper than I could get anywhere including shipping and I had them throw in some nylon pads. If you are splitting the case anyway put in a new chain. Its worth it for about a hundred bucks.
    MrMarty51 and Jaryd like this.
  9. Sand
    Sand Active Member
    188
    198
    Mar 27, 2016
    Canada
    Im in Canada. I know the pain of shipping. Im thrilled Rockauto does reasonable shipping here now. They're great. Couldn't find the nylon pads with them though...
  10. WarWagon
    8,246
    2,685
    Nov 15, 2009
    AZ
    Good news! It's not the transfer case! :D
    Bad news! It's doesn't matter as it still comes out with the transmission. :facepalm: Trans is taking time to grab reverse or 1st.
Share This Page
