SS Pre-Bent Brake Lines
Discussion in 'Drivetrain' started by nobby, Sep 14, 2010.
  1. nobby
    nobby Old Timey Diesel Guy
    417
    6
    Nov 5, 2008
    Long Island NY
    So I promised Dracor85 quite awhile ago that I would post pictures of the complete Stainless Steel pre-bent brake line kit that I purchased from Inline Tube to show how accurate they are. Firstly my apologies to him for taking so long. Anyways finally after a line failure I finally got around to installing the kit and hence take pictures as well. I have taken pictures of the old line next to the new one. The quality and fit is excellent and the lines are bang on in accuracy and bend location. At the time I ordered they did not list my burb however they assured me they had the specs and since then they have listed my truck along with other new ones. Not that I had to use this but they also assured me that they would work with you if a line was bent incorrectly. I only had one issue and that was that the line that runs aft the length of the chassis leg was bent 180 DEG in the wrong direction at the very first bend at the fwd end of the line (see the last pic). This was however an easy remedy so I did not try to return it. I will send them an email just making them aware of this issue though so that they can double check their specs for future customers. All lines come with plastic caps and the one long rear leading line is bent gently in half in the long straight run for packaging, they place a tag at either side of this shipping bend so as to guide you where to straighten it.
    As far as I am concerned buying this kit is a no brainer $195.00 for a SS kit that fits right in is a very good price as far as I am concerned. Sure you can do it all yourself as have I in the past and I have the bending and flaring tools. However time wise its a quick install and you would no doubt in time spend more than their price bending it if you account for material costs. As to replacing all lines well if the rear has gone then the one that runs around the front to the passenger side and the driver side also are pretty much close to go themselves.
    Cheers
    Nobby
  2. bk95td
    bk95td 6.5 nut job/addict
    2,548
    9
    Nov 26, 2008
    Nice. Sounds well worth it if all the fittings are stainless also. Do they also make fuel line kits in stainless? If your rear brake line went ,the fuel lines are next, soon.
  3. nobby
    417
    6
    Nov 5, 2008
    Long Island NY
    Fittings were not Stainless but can be special ordered for an extra charge. As far as I am concerned the fittings are not really an issue and never-seize takes care of the threads.
    Fuel lines are in much better shape and I waxed them all when I got the truck. When I get a spare bit of cash I'll probably change them out as a preventative measure. They do make SS fuel lines I have not checked if they cover our applications.
    Cheers
    Nobby
  4. dracor85
    dracor85 New Member
    56
    0
    Mar 15, 2009
    Pittsburgh, PA
    Thanks Nobby, the pix say it all looks like factory parts just in SS. I think that they do make the SS fuel lines for our trucks but Ill have to double check.
  5. dracor85
    dracor85 New Member
    56
    0
    Mar 15, 2009
    Pittsburgh, PA
    ok just checked no fuel lines for the diesels only for the gas jobs but they also make the flex hoses for the brakes in SS and also the transmission cooler lines in SS.
  6. nobby
    417
    6
    Nov 5, 2008
    Long Island NY
    Just a thought but based on my experience the catalogue does not say it all, I'd suggest calling them before deciding that they cannot make the fuel lines.
    Cheers
    Nobby
  7. Matt Bachand
    Matt Bachand Depends on the 6.5
    5,330
    7
    Jun 10, 2008
    Worcester, MA
    This is a great thing to have. Even just to buy ahead of time, so when there is a failure you have a prebent line ready to fix her up. SS is a super plus.
    With these older rigs, most of our lines must look a little fatigue, and if you saw what the older rigs brake lines looked like in the salt belt..... trust me, you don't want to see it.
  8. HighSierra86
    HighSierra86 Member
    736
    4
    Mar 30, 2009
    Connecticut
    I was just thinking of this yesterday and wondering if anyone makes bre-bent ss lines. Great timing on the thread! Thanks for the info and pictures. The price for a full kit is well worth the price imo. I always bend and flare my own lines, just to replace them a few years later when they rot out. My 95' will be getting these when i get that far.........
  9. nobby
    417
    6
    Nov 5, 2008
    Long Island NY
    Precisely what I did Matt, pre-purchased and then waited for the fatefull soft pedal day!
    Also too in conversation with them they'll work with you with issues even if it does take you a while to install. I called them about a possible issue and they were not put off by the 8 month lapse in the purchase date.
    Cheers
    Nobby
Share This Page
