Speakin of winches
Discussion in 'General Recreation' started by Trailmaster01, May 10, 2008.
  1. Trailmaster01
    Trailmaster01 Marshall
    332
    1
    May 3, 2008
    New Jersey
    Post a picture..and/or tell us about your winch(es)...any problems??Anything about your winch or general questions.
  2. Trailmaster01
    332
    1
    May 3, 2008
    New Jersey
    I'll start
    I have a Warn 9500i that is being rebuilt...I am looking into gettin another 9500....the earlier 9500i(like mine) is notorious for not being very water resistant..therefore the brushes get corroded very quickly. BTW..it is on a cradle and is inserted into my 10,000 lb reese receiver in the front....in front of the brushguard
  3. bighawg
    bighawg Proud Rider of the Short Bus
    3,380
    3
    May 9, 2008
    Carnesville, Georgia
    I've got a Ramsey 12000# worm worm gear drive on the front of mine. Have not got to use it yet, kinda looking forward to it though. Mine seems to be the real deal, see them on the back wreckers quite a bit.
  4. Trailmaster01
    332
    1
    May 3, 2008
    New Jersey
    Yea..they ARE popular on those wreckers
  5. Tom S.
    Tom S. Killing time
    75
    0
    May 4, 2008
    Waterford, MI
    Here's mine on the front. I don't have any pictures on the rear yet.
  6. DunesRunner08
    DunesRunner08 Banned
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    I have milemarker, warn, bulldog, superwinch, and t-max winches...I mess with all of them constantly and to be 100% honest with you....I prefer T-max and Superwinch over anyone else.....the warn are good and last a long time, but they are way way way over priced.....I have broken numerous remotes on the milemarkers and they make me buy new ones....no warranty there, and bulldog's are the most inexpensive out there, they are the same as Atlas, Titan, and a bunch of other comapanies that are made in china by C&N Manufacturing...cheap product, cheap price, will work for guys who don't use a winch a lot.....
    T-max 15k winch out pulled my 16.5Ti warn and was $600 les expensive....Superwinch 16.5 costs less than warn too!!! My 12k superwinch has kept up with the warns I have with no hiccup!!
    Thats just my .02
  7. Trailmaster01
    332
    1
    May 3, 2008
    New Jersey
    Good info...the Warns ARE overpriced....the only one i can think of that you didn't mention was Ramsey...curious to know what you think of those..
  8. bighawg
    3,380
    3
    May 9, 2008
    Here's mine
    Yeah, what do you think of Ramsey's?
  9. HemisAreSlow
    HemisAreSlow FREE!!!
    1,078
    1
    May 3, 2008
    any idea if anyone makes the front reciever hitch for the new body style yet? I'd like to get a winch but don't want to permanently mount it
  10. DunesRunner08
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    I never used the ramsey...so I don't want to give an opinion...I have heard both good and bad about them though
  11. Trailmaster01
    332
    1
    May 3, 2008
    New Jersey
    OK thanks
  12. DunesRunner08
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    The best advice I can give you is this
    If you use your winch everday...spend the money on a warn, a T-max, or a Superwinch...No matter what you buy stay away from hydraulic, and if you only use it on occasion, save your money but still buy one that reputable
    with that said, Ramsey would be in the last catagory....
  13. Trailmaster01
    332
    1
    May 3, 2008
    New Jersey
    I would never get a hydraulic.....lol....thanks for the advice
  14. Ranger
    Ranger Spoolin that turbo ;0)
    Interesting, considering hydraulics are stronger, more line speed and more cable capacity...
  15. DunesRunner08
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    and if you bury your truck in mud and/or water and your engine dies you have no winch....if I am winching myself out, I want to make sure I can get out...electric will work underwater...hydraulic wont... as for being stronger...what your winch is rated at its rated at whether its electric or hydraulic....also when a hydraulic breaks its a lot more expensive to fix
  16. Trailmaster01
    332
    1
    May 3, 2008
    New Jersey
    Basically yea they are in some respects but there are reasons why I won't buy one...if you'd like to know what those reasons are I'll be glad to tell you:sifone:
  17. Trailmaster01
    332
    1
    May 3, 2008
    New Jersey
    Exactly..you made my work easier...one more thing...I do not like the asethic(spelling) appeal
  18. Tom S.
    Tom S. Killing time
    75
    0
    May 4, 2008
    Waterford, MI
    Hydraulics do have one major advantage: they can be used continuously, where as electric winches get hot and have to cool down. Other than that, all the advantages go to electric.
  19. Trailmaster01
    332
    1
    May 3, 2008
    New Jersey
    Precisely:thumbsup::gnorsi:
  20. red
    red stubborn Texan displaced to Utah
    1,536
    247
    May 17, 2008
    Eagle Mountain, Utah
    where did you hear that hydraulics wont work underwater? sorry but you've got that info backwards because its electrics that you can fry by trying to run them underwater.
    electrics:
    upsides:
    can run with truck off
    much faster line speed unloaded
    downsides:
    overheat easily, have to take breaks
    drain battery's very quickly if the engine is off, lucky to get 2-3 minutes of pulling time
    most wont work underwater
    hydraulics
    upsides:
    dont need to cool down, no breaks required
    ALWAYS work underwater (been offroading for the past 10 years and i've done this too many times to count with no issues)
    pull faster than an electric WHEN LOADED
    downsides:
    power steering pump must be working
    slow line speed when unloaded, nearly the same as when loaded
    both types have their ups and downs, an electric is simpler to install expecially if you use a removeable setup. connect the wires and go. i prefer hydraulic, been around too many electrics that have overheated and taken way too long to pull somebody out because of that. if you go hydraulic, mile marker (their electrics arent very good but ok).
Share This Page
