PTO?
Discussion in 'GM Manual Transmissions' started by Michaeljp86, Jan 25, 2011.
  1. Michaeljp86
    Michaeljp86 EVIL GENIUS
    1,614
    0
    Nov 5, 2008
    MICHIGAN
    Im not familiar with GM manual transmissions. Can you put a PTO on any of them? Id like to build a wrecker and would like a PTO to run a hydraulic pump.
  2. GM Guy
    GM Guy Manual Trans. 2WD Enthusiast
    4,662
    440
    May 6, 2008
    NW Kansas and SC Idaho
    yes sir, there are PTos available for the NV4500. one pops up on E-bay every once in a while. I would say go to a salvage yard so that you get one with all the install stuff needed. (are they all lever or cable engage, or do they have solenoids on them yet?) not up on my pickup PTOs.. I do know they have air shift on the bigger trucks, but as far as pickup PTOs, I am kind of lost!
    I dont know if the truck needs the PTO prep package, as I think the duramax generation needs it selected so that there is more floorboard clearance, IIRC.
  3. GM Guy
    4,662
    440
    May 6, 2008
    just typed in PTO on E-bay and plenty popped up. didnt see any that specifed NV4500 though.
  4. Michaeljp86
    1,614
    0
    Nov 5, 2008
    MICHIGAN
    I found about 4 of them on ebay that I think would work. I was reading about the allison 1000, other then that I dont think you can get a PTO on a GM automatic.
    Mosth if the wreckers I seen have a cable to engage it, some of the new ones may be electric.
  5. GM Guy
    4,662
    440
    May 6, 2008
    I think the big borg-warner cases on the 1 tons might be PTO capable themselves, so that is how one cheats with an auto. or get an engine driven pump.
  6. Michaeljp86
    1,614
    0
    Nov 5, 2008
    MICHIGAN
    How does a PTO work, on a transfer case wouldnt you have to have the transmission in drive to run a pto?
  7. GM Guy
    4,662
    440
    May 6, 2008
    yes you would. IDK if setting the cruise with t-case in neutral would do it or not.
  8. Michaeljp86
    1,614
    0
    Nov 5, 2008
    MICHIGAN
    I think you put the T case in neutral and then run the PTO through the transmission.
  9. GM Guy
    4,662
    440
    May 6, 2008
    yes, but I was wondering how to set it so that it maintained pto speed. maybe a n OEM PTO prep package will have tcc lockup built in?
  10. Michaeljp86
    1,614
    0
    Nov 5, 2008
    MICHIGAN
    Im not sure about a tcc lockup, I heard on the dmax with a allison 1000 you set the cruise to hold the speed. Seems like a tcc lockup would be about the only way to go.
Share This Page
