  2. Texas and Louisiana needs your help!
    We have members affected with this storm.
    Update: Crowdfunding Link by JJ Watt of the Houston Texans: Go Here
    Dismiss Notice
Oil coming out the exhaust manifold?
Discussion in 'GM 6.5 Diesel Engines' started by Bigburban, Nov 28, 2010.
  1. Bigburban
    Bigburban New Member
    152
    0
    Jun 6, 2010
    Tennessee
    Well I was checking the Burban today and noticed a small amount of oil that appears to be coming out of the exhaust manifold where it connects to the engine 1st cylinder passenger side. Any ideas? Should I worry? No weird noises and runs fine.
  2. NVW
    NVW Well-Known Member
    8,427
    785
    May 5, 2008
    Castor, AB.
    In that location it could be from the turbo drain tube leaking on the manifold.
  3. Bigburban
    152
    0
    Jun 6, 2010
    Tennessee
    I have not had a real chance to look at it but that makes sense I changed that injector out last week but didn't replace the gasket on the drain pipe.
  4. Turbine Doc
    Turbine Doc Just Another Diesel Guy
    Red RTV applied sparingly so that it doesn't ooze over into the drain cavity when compressed, is what I use now when I I do turbo swaps if I don't have a new gasket handy, or I tap out a gasket from sheet gasket paper
Share This Page
