LBZ/LLY Belt squeak fix
Discussion in '06-07 LLY/LBZ' started by blizzardplowman, May 4, 2008.
  1. blizzardplowman
    blizzardplowman Crowd Control Staff Member Moderator
    655
    0
    May 3, 2008
    SE WI
    Get the updated belt. Fixed mine, hasnt made noise since
    Subject: LBZ LB7 LLY 6.6L Duramax Diesel Engine Accessory Drive Belt Chirp, Squeal or Squeak Type Noise at Cold Start Idle (Replace Accessory Drive Belt) #07-06-01-003 - (03/07/2007)
    Replace with GM
    Accessory Drive Belt (1367 mm) Part Number 98035628
    Note number is for single 145 amp alt.
  2. schulte
    schulte ACCELLERANT!!!
    420
    0
    May 4, 2008
    Southern CT
    Hm. Is the new belt any different? Is it just a GM branded Goodyear Gatorback?
  3. PDXLBZ
    PDXLBZ New Member
    12
    0
    May 17, 2008
    Oregon
    I think they finally got mine whipped. They put the updated belt on and drilled out the power steering pulley bracket per the TSB.
  4. MAX4X4
    MAX4X4 Recruit
    54
    0
    May 4, 2008
    CA
    Do they have a fix for the dual alternator setup?
  5. 12ga diesel
    12ga diesel Jack of all, Master of none
    1,766
    30
    May 4, 2008
    McHenry,IL
    Sorry to be the one to ask the "dumb" question, but when are you guys getting the belt squeak? When I turn the truck off, as soon as the key gets to the off position, I get this what you could call a "squeak" from the engine that last no more then a quarter second. Just wondering if this is the same thing that I have seen talked about before. My '05 LLY never did this and this truck has done it pretty much since I bought it (bought it used with 79k miles). Thanks for any answers.
  6. addicted
    addicted To Him
    70
    0
    May 9, 2008
    Indiana
    I never got it at shut down only at start up. The gatorback fixed it for me.
  7. PDXLBZ
    PDXLBZ New Member
    12
    0
    May 17, 2008
    Oregon
    My squeak was occasional at first. The stealer said they only needed to clean my belt. That fixed it for only a few hundred miles before it returned. The squeak returned and was constant and would drive me absolutely nuts at idle. It went from "is this only in cold weather?" to doing it all the time.
    I presented them with TSB 07-06-01-003 (replacement belt) & TSB 1870272(power steering pump pulley bracket alignment). They did both which seems to have fixed it. I didn't see it when I just looked up TSB 1870272, but I thought they were prescribing drilling out the power steering pump pulley bracket holes out to allow for greater alignment play. This might be in TSB 05-06-01-018A. I'll be damned if I can find 05-06-01-018a right now. I just looked for ten minutes for the dang thing. Also, if this didn't fix it, they could move the pulley 1mm on the shaft ( I believe towards the fire wall) to eliminate any remaining noise.
    My engine has been purring with no squeak. Now if I can get a rear slider that doesn't leak like a sieve.
  8. 12ga diesel
    1,766
    30
    May 4, 2008
    McHenry,IL
    The belt squeak I'm getting isn't concerning me too much right now, like I said, it's nothing I have hear on this or my other Dmax. It's just at shut down, so if it starts happening at start up, or while the truck is idling/running, then I might take it to the dealer along with the TSB, and have them fix it. I still have about 17,500 miles left on the engine warrenty, so I still have some time to see what will happen.
  9. sodfarmer
    sodfarmer Movin on up.
    101
    0
    May 10, 2008
    Northern Utah
    IIRC there is another bulletin for squeak at shutdown. I believe they replace the alternator with a clutched one.
    good luck.
  10. dentpusha
    dentpusha LOCKED&LOADED
    881
    0
    May 9, 2008
    a-town texas
    i need to get mine done,but it hasnt been doing it since the weather has warmed up a bit.but in the winter ittl scream like a stuck pig
Share This Page
