LBZ fuel gauge sucks.
Discussion in '06-07 LLY/LBZ' started by dmaxfan, May 12, 2008.
  1. dmaxfan
    dmaxfan Iliketomakewerewolfmovies
    55
    0
    May 12, 2008
    North Little Rock, AR
    On 1/16 of a tank you may be able to put in 20 gallons. I assume everyone is having this problem. The LB7 was the complete opposite.
  2. MGlickLBZ
    MGlickLBZ Agent Quack Smacker
    234
    0
    May 5, 2008
    South Central, WI
    I would agree with you. I start looking when I get to a 1/4 of a tank. Even then it might take either 16 gallons or 22 gallons.
  3. truckie481
    truckie481 Dagum
    682
    0
    May 4, 2008
    Cleveland, NY
    I almost always run untill the low light comes on and it seems consistant to me, I have not run out yet.
  4. richard cheese
    richard cheese the MAIN muff hugga
    345
    0
    May 7, 2008
    my lb7 fuel gauge sucks azz.... by 3/4 of a tank, ive used more than half of my tank (26 gal tank, with 17 or so to fill up.....) by 1/2 tank, i will have to put in 22 gallons....
    ****ing pieces of shit...
    but hey,,,the rest of my truck works pretty damn good
  5. dmaxfan
    55
    0
    May 12, 2008
    It is the complete opposite for the LBZ. That is why people think their LBZ isn't getting as good as an LB7.
  6. BigBlueBurban
    BigBlueBurban Umm no...WAIT...yes
    98
    0
    May 7, 2008
    Grand Rapids, Michigan
    I typically run mine down right until the low light comes on. Even then, the most I've ever pumped into my stock tank is around 22 gallons.
    What I've also noticed is that right after filling up, the fuel gauge never reads full, it has to work its way up like a Toyota's or something. Never had that problem with my Suburban.
  7. MGlickLBZ
    234
    0
    May 5, 2008
    South Central, WI
    My gauge does the same thing when I fuel up while the truck is running. If I turn the truck off and restart it states that it's full. Anymore, the pump looks like a frigging slot machine.:D
  8. 12ga diesel
    12ga diesel Jack of all, Master of none
    1,766
    28
    May 4, 2008
    McHenry,IL
    Yep, same here. As for the gauge itself, it seems to be pretty true for me. Unless I have to, I never let it get much lower then 1/4 full. At 1/4 tank, I can get about 16-17 gallons.
  9. tomrex
    tomrex Professional Idiot
    Mine's goofy too. I normally let the light come on, go 50-55 miles and then fillup. I've NEVER put more than 22 gallons in. Weird.
  10. joverman
    joverman Recruit
    18
    0
    May 8, 2008
    Harmony, NC
    Every GM I have ever had has been like this(That would be all of the cars/trucks I have ever owned) it is annoying but after 14 yrs I have gotten used to it. I usually try to fill up around 450 miles that way i give myself a 50 mile window to find fuel.
  11. saratoga
    saratoga Unpaid Help Staff Member Moderator
    4,535
    56
    May 3, 2008
    Lithia, FL
    Which is why I use the trip odo as a reference as to when to fill up and the gauge for a quick glance only.
  12. Tow Master
    Tow Master New Member
    235
    0
    May 15, 2008
    Irwin, Pa
    I agree. I dont run mine low much but I hate it when I fill the tank up and it takes a while for it to go to full. You'd think with all the money and the pain it would be if the diesel ran out of fuel they'd perfect that!
    Now my 99 PSD down right scares me! You can drive it for 30 miles on halph a tank. Shut it off start up and it magically goes down to 1/8 :mad5:
  13. scoot
    scoot Recruit
    120
    0
    May 5, 2008
    Bloomington, IL
    my guage takes a while to read full as well after i fill up. but i was told that when the light comes, on at least in my gas truck i had, that there was a reserve built in once it got to empty, there was still a couple of gal in it, and it had a 26 gal tank and i never put more than 20 in that when the light came on i wounder if they did the same for diesel
  14. btfarm
    btfarm 300,000 Worth Staff Member Moderator
    16,098
    1,383
    May 12, 2008
    Sandwich, Illinois
    They've always been that way. Gotta shut down at fill up if you want a reading right away.
    Exactly...
  15. BKDespain
    BKDespain Recruit
    184
    0
    May 8, 2008
    Utah
    x2 on going off the odo. I have yet to put over 22 gal. in mine and it was past E.
  16. Hopalong
    Hopalong Rode hard, put away wet
    32
    0
    May 11, 2008
    Central Coast Ca.
    The last half of the tank, especially the last 1/4, goes a lot faster than the first half.
    I've found myself with a 1/4 tank, and thinking that I could make it to a certain spot, then sweating bullets 10 minutes later when the light comes on.
    I look at the 1/4 mark as the empty mark now.
  17. BKDespain
    BKDespain Recruit
    184
    0
    May 8, 2008
    Utah
    I filled up on the 1/4 tank mark 2x and it took 15.5 gal each time.
  18. Yibbutkeen
    Yibbutkeen Recruit
    70
    0
    May 5, 2008
    Mine seems accurate enough. Light comes on at 22 gal used.
  19. DuneMe
    DuneMe Republican
    39
    0
    May 11, 2008
    Elk Grove, CA
    The LLY isn't much better.
    When the light comes on you have no more than 100-yards to pull-over and re-fuel. The reality is that light isn't a warning light it is a light that should just say, "Ha, ha, ha - You're Screwed!"
    Get a bigger tank! Only downside is WHEN you fill it up.
  20. dtibbals
    dtibbals Official Gun Nut
    On my LBZ the fuel gauge is very accurate. If I fill it up while its running it will not go all the way to full unless I turn it off and restart it. It will go to full after 10 min or so with out restarting. If I fill up with the truck off it will always go to full when I start it.
    My DIC is dead on! I reset the fuel used every tank, that way I know I have a 26 gallon tank and can tell how much fuel I have left by looking at how much I have used. If it says I have used 12.8 gallons I will be able to fill it up with in a 1/10 of a gallon to what the DIC says. I always fill right up to the cap so I know I am getting the same amount each time.
    20/20 once did a special about how far cars can go till they run out of fuel when the gauge reads empty. They found that after the gauge reads empty and your range says you have no more distance the average American car went something around 50 miles or more before it ran out of gas. A letter by Chrystler said that they build in a safety reserve into the gauge and range estimates to insure you do not run out of fuel. They said the American consumer wants that safety net. Import cars have a safety net built in but a much lesser amount of "reserve" fuel. It seems that US car makers tend to have 2-5 gallons of fuel left when the gauge reads empty while import car companies tend to be 1-2 gallons until they run out of fuel.
    I tend to get fuel at the half a tank to 1/4 tank left. The light has only come on one time and that was when I first test drove it at the dealer.
Share This Page
