Kubota
Discussion in 'Tractors & Farming' started by gmctd, May 7, 2008.
  1. gmctd
    gmctd Diesels, Anonymous
    565
    0
    May 3, 2008
    texas
    Got a Kubota 5600 HST 3cyl Diesel lawnmower - engine and chassis is too heavy for the steering, so wears the pinion gear badly - got a 80 Datsun manual steering box, gonna put that in there with a arc wrench, bet that sucker will steer from now on - plus, got the kit to overhaul the engine, as excessive blowby was making it hard to start - also got a little perkins turbo to put on it, just for the novelty - dunno if that HST will hold the increased Diesel power, but the turbo whistle and a short stack should set it apart from the average lawnmower in suburbia
  2. SfcJones
    SfcJones A(ACLU) SGT. SLAUGHTER
    3,508
    25
    May 3, 2008
    South Ga.
    Should have just got ya a B3030 Cab model with a belly deck, with the AC running during the summer time the neighbors will look at you with envy, I can do 4 acres in 65 minutes,
    let me know how the turbo works out, when my goes out of warranty I might try that on mine, hopefully it will have a waste gate...
  3. Cheyenne19
    Cheyenne19 Special agent C19 A(ACLU)
    540
    0
    May 4, 2008
    The Delta
    If only my MF 253 had a cab.
  4. GM Guy
    GM Guy Manual Trans. 2WD Enthusiast
    4,679
    454
    May 6, 2008
    NW Kansas and SC Idaho
    A cab? I wish my mowing fleet had at least a sunshade! (322 JD I3 Yanmar gas, Sears yard tractor 2 cyl Briggs gas, wish i had a small diesel!)
  5. SfcJones
    3,508
    25
    May 3, 2008
    South Ga.
    mine has a cab with AC and heat, wipers, front and rear lights, hydra drive tranny, 4wd, class 1 3 point hitch....I do alot with mine, bush hog, finishing mower, rotary tiller, pole auger, box blade, rear rake..
  6. bighawg
    bighawg Proud Rider of the Short Bus
    3,380
    3
    May 9, 2008
    Carnesville, Georgia
    I've got a ZD21 Kubota with a 60" deck, I can mow about 4 acres an hour, if the grass is not to heavy. It will run 9 mph. No Cab though.
  7. Mr Baadboy
    Mr Baadboy New Member
    81
    0
    May 16, 2008
    Springfield Tn
    Loss of Power
    I have a kubota three cyl diesel Bx 1800 about 9 years old it seems to have slowed down the last few years. What kind of tune up do you think i can do to restore the lost HP I due all the maintance myself Oil/ filters etc.....
    can i clean injectors and glow plugs ? Or just replace with new , dosen't burn or leak oil , I have have replace several of there hydro hose's (cheap)
    60" mower, Bucket, 5' scraper blade, pulls a four gang disk afew times a year.
    Ps. Anybody have a permanet fix for the blade height adjustment Knob (plastic piece of S--T) been through 3 the plastic sleeve strips every couple years so now i just use a vice grip to adjust settings and looks like hell but it turns the Shaft!
  8. gmctd
    565
    0
    May 3, 2008
    texas
    Pull the injectors and IP and have them tested at a local shop - definitely new\rebuilt injectors, tho - gp's only help at start
Share This Page
