3-4 shift sloppy
Discussion in 'GM Allison' started by ServiceOnSite, May 22, 2008.
  1. ServiceOnSite
    ServiceOnSite New Member
    12
    0
    May 21, 2008
    ive got 40 k on my 06 lbz and seems the tranny is sloppy going into 4th gear. i have a bully dog triple dog set on tow mode have played a few times on extreme but nothing to hard. is there anything i can do short of a rebuild to firm this up???? i really didnt want to go all out untill i hit 100k when the warrenty is up. any help would be great. thanks
  2. DunesRunner08
    DunesRunner08 Banned
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    transgo kit would help you out a bit and they are easy to install
  3. ServiceOnSite
    12
    0
    May 21, 2008
    what type of time/ how hard are we talking here???
  4. t2ch
    t2ch New Member
    443
    0
    May 9, 2008
    Charlottesville, Va
    The jr. is probably going to be a band aid at this point. The install is not that hard. You have to remove the valvebody and replace some springs and check balls.
    It's a mess but can be done in the driveway.
    Fill out your sig so we know what your truck is.
    How hard do you drive the truck? How heavy do you tow? How much have you played on the higher levels? Did you give the tranny time to learn the new power before you started "playing"?
  5. jcool
    jcool #78 A(ACLU) FNG
    1,097
    0
    May 4, 2008
    Richlands, NC
    3-4 flare... mine did it for a little while before the tranny learned the tune. if you keep adjusting the power the tranny will never learn and continue to act up. also, when was the last time you changed your spin on filter?
  6. dentpusha
    dentpusha LOCKED&LOADED
    881
    0
    May 9, 2008
    a-town texas
    i had that problem when i had the bullydog also.ive since swithced to ppe and no longer have the problem.id start by changing the spinon filter
  7. jcool
    1,097
    0
    May 4, 2008
    Richlands, NC
    it took me about 250 miles for the tranny to shift right, now i leave in on extreme normally and towing when i engage t/h mode so i dont have to go through the "break in period" every time
  8. Philbilly2
    Philbilly2 Just a speck on the wall
    x2 on the break in. It makes all the difference in the world!
Share This Page
