2001 silverado
Discussion in 'All Other Transmissions' started by Joe Salotti, Jul 23, 2016.
  1. Joe Salotti
    Joe Salotti New Member
    4
    0
    Jul 16, 2016
    usa
    Can any one tell the difference between a 2000 4l60e and a 2001 4l60e. have both 2001 no forward 2000 works fine. both are off 5.3L. 2000 out of suburban want to put it in 2001 Silverado. Both 4x4
    Thanks
  2. THEFERMANATOR
    8,820
    2,021
    May 9, 2008
    ZEPHYRHILLS FL
    Should work fine. Since they're both from a 5.3l, they both have the same converters and bellhousing patterns, and since they're both from an LS engine, they already use the EC3 lockup system. Just make sure thats your problem, otherwise ylu could be swapping trannies just to have the same problem.
  3. Joe Salotti
    4
    0
    Jul 16, 2016
    usa
    What else could it be? I was pulling out on to the road and heard a bang and then no forward motion.
    Thanks for the help with this I have been told so many different things it was getting confusing.
  4. Will L.
    Will L. Well-Known Member
    6,904
    4,920
    Jan 25, 2013
    Boulder City Nv
    How does the engine run?
    What happens when you put it in Drive? 1st? Reverse?
    If you jack up the axle do the wheels and drive shaft spin freely? Anything look out of the ordinary?
  5. THEFERMANATOR
    8,820
    2,021
    May 9, 2008
    ZEPHYRHILLS FL
    Does it move at all? Have you tried putting it in 4 low and see if it moves? A loud bang with no more movement sounds more like transfer case than transmission. Unless you were really getting on it, I would find it hard to believe a shaft or clutch broke in the trans, but it isn't that uncommon for transfer case problems to occur and cause this.
    Will L. likes this.
  6. Joe Salotti
    4
    0
    Jul 16, 2016
    usa
    It will backup but not move forward no matter where the transfer case is put. Will roll down hill without a problem. did not see anything when I was under it.
  7. THEFERMANATOR
    8,820
    2,021
    May 9, 2008
    ZEPHYRHILLS FL
    What if you try putting it into 2 with the shifter?
  8. Joe Salotti
    4
    0
    Jul 16, 2016
    usa
    tried all spots nothing works to go forward, only backwards
Share This Page
