Buy Viagra with Dapoxetine online at our pharmacy. No prescription required. Lowest price guaranteed. Free Worldwide Shipping. Reorders huge Discount.
buy antibiotics online
THIS AD DOES NOT APPEAR TO REGISTERED USERS!
Page 12 of 16 FirstFirst ... 28910111213141516 LastLast
Results 166 to 180 of 240
Thread: Injector Nozzles
  1. #166
    Been there, broke that.
    Join Date
    Oct 2011
    Lancaster, PA
    Posts
    463
    Member #
    9422
    Default
    I got a set same place 6.2turbo got his. Mine said germany.
    1994 K1500 3.8 - vm638. hx30/hx52 4l80e
    1992 K1500 3.9 - Fuel and air mods.
  2. #167
    Registered User 6.2 turbo's Avatar
    Join Date
    Jan 2010
    pa
    Posts
    1,292
    Member #
    5159
    Default
    Not to worry,I can fix them. Pretty sure they are just sticking.
    92 Chevy truck modified 6.2 diesel, Has spun bearings 97 Chevy truck solid axle and 5.9 cummins no fuel plate, 370 marine inj,valair twin disc clutch. 96 4 door Tahoe getting a 6.5 diesel swap
  3. #168
    9 11 Never Forget Brooklyn Tow's Avatar
    Join Date
    May 2008
    Brooklyn, NY USA
    Posts
    3,235
    Member #
    163
    Default
    Whats all the trouble with the Bosch squirts, are they Marine setups?......Whats needed to get a decent set of injectors/Nozzels?
    Is it the Nozzels, Reman, New, Frankenstein?......I thought Bosch Germany were supposed to be quality you can trust?
    Maybe Delco or Stanadyne INDIA arn't that bad.
    Anyone with experience good or bad That could elaborate a little?
    Louis
    96 3500HD Dynamic Wrecker....3" DP to 4" Exhaust....Severe Duty Fan Clutch....D Max 21" Fan Blade.
    Member#2 Massive Blowby Club
    Member#43 DTR/TTS Dually Club
    Member#5 RC Club
  4. #169
    Registered User buddy's Avatar
    Join Date
    Nov 2008
    California, central coast
    Posts
    6,093
    Member #
    2043
    Default
    I know someone that has worked with a lot of German Bosch nozzles and never had an issue when new. Thats not taking them out to inspect down the road, although thats what was in there from the factory, some guys ran for 200,000 miles.
    94 6.5TD C1500 ECLB w/ 50 gallon aux tank/box; 235/75R17 tires on Alloy wheels; 3.42 gears; A-Team Turbo; 4" Aero Turbine 4040 muffler to 5" Aero Turbine 5050XL muffler to 6" tip before rear axle; FSD heatsink, marine injectors; "F" intake; SynBlend 10W-30 oil; Walbro FRB-5 w/ 12 micron prefilter; Feed The Beast; WMI and Propane fumigation; OPS extension & relay; 110K original miles; Engh GMTDScanTech
    Near Future: Battery relocation, Amsoil Nanofilter behind headlight, and stereo upgrades
    Veterans of America Club, member #18
  5. #170
    Join Date
    Jan 2010
    pa
    Posts
    1,292
    Member #
    5159
    Default
    Not sure why mine gave me so much trouble. They wanted to leak before I even ran them. I did use Delphi holders,since they have a bigger inlet hole. Maybe I should have used Bosch holders ?
  6. #171
    Join Date
    Nov 2008
    Posts
    6,093
    Member #
    2043
    Default
    Do you replace the heat shield, bottom washer/gasket thing with every rebuild? Not sure that would affect performance before use, but might not last as long in use.
  7. #172
    Join Date
    Jan 2010
    pa
    Posts
    1,292
    Member #
    5159
    Default
    I just clean them usually. It think some of the Monarchs are leaking now. They are set at 3200 psi,the Bosch marine were 2400 psi. At low fuel output,high psi might be an issue. The pintles can't lift,so they will leak instead. I do know for a fact ,that lower pop psi creates a smoother idle.
  8. #173
    Registered User nmb2's Avatar
    Join Date
    May 2012
    ft lewis, wa
    Posts
    209
    Member #
    11082
    Default
    why do you set your pop pressures so high? What is your idea behind this?
  9. #174
    Join Date
    Jan 2010
    pa
    Posts
    1,292
    Member #
    5159
    Default
    It seems to help top end power. I have tried pop psi from 1600-5000 psi.
  10. #175
    Join Date
    Nov 2008
    Posts
    6,093
    Member #
    2043
    Default
    Quote Originally Posted by nmb2 View Post
    Because cylinder pressure will exceed pop pressure at high CR and boost.
  11. #176
    Join Date
    May 2012
    ft lewis, wa
    Posts
    209
    Member #
    11082
    Default
    interesting theory. I'm going to have to sleep on it.
  12. #177
    Join Date
    Nov 2008
    Posts
    6,093
    Member #
    2043
    Default
    Not a theory, physical fact, CR of 21:1 and 20lbs of boost will put your cylinder air pressure at TDC over a pop pressure of 2200psi. There is some pressure bleed down past the rings, but less and less with increasing RPMs.
    So if someone wants to run 30psi of boost they really should be setting the pop up to 2700psi or so, or drop the CR to compensate for the extra boost. The cylinder pressure could still be greater than 2700psi, but thats a pop pressure "limit" I recommend based on similar hardware out there. So I pretty much recommend no one run more than 25psi of boost on these setups, and use an intercooler if needing more air mass flow. Or lower the CR to 19:1 and you can run 30psi of boost reliably wrt to injectors at 2700psi pop.
    I introduced this info a while back and surprises me it has never come up in the past. the IP can push through cylinder pressure, because its capable of up to 10,000psi, but you dont want to be popping below your expected TDC cylinder pressure at load. Attached a calculator I made so you can see how CR and boost affect TDC air temp and pressure for whatever platform youre using. Its quite profound, and should be no mystery why heads can blow off from high boost, how we get crankcase pressure and shows exactly how 1F IAT drop can lower cylinder temps by 3F.
    Attached Files Attached Files
  13. #178
    Join Date
    May 2012
    ft lewis, wa
    Posts
    209
    Member #
    11082
    Default
    very interesting thought. I use 2100psi on my injectors we built.
    So @ WOT my injectors never fully close you think?
  14. #179
    Join Date
    Jan 2010
    pa
    Posts
    1,292
    Member #
    5159
    Default
    It should take a lot more cyl psi than pop psi,to open the pintle from the outside. The outside surface area is only .040,the inside area that the fuel lifts against is bigger. It's not like a check valve.
  15. #180
    Join Date
    Nov 2008
    Posts
    6,093
    Member #
    2043
    Default
    I really think of the problem being that you inject into higher pressure, so you'd get really poor atomization and spray pattern/direction. May be forcing the fuel out while its starting to burn due to really high air temp as well. Not a good thing in general for efficient combustion. Probably get burnt nozzle tips and other issues if running long stretches that way. And once the nozzles start pissing then other bad things can happen. Its just good to understand the system as a whole, and mitigate any issues.
Similar Threads
  1. Stock vs Marine injector nozzles
    By crash2win64 in forum 6.5 Performance
    Last Post: 11-24-2011, 04:30 PM
  2. Legit Marine Nozzles
    By Woody35 in forum 6.5 Performance
    Last Post: 06-04-2011, 11:58 PM
  3. Injector nozzles?
    By THEFERMANATOR in forum 01-04 LB7
    Last Post: 05-06-2009, 09:18 PM
  4. A Civic's Eye view of 160 HP nozzles....
    By Cumminalong in forum All Other Diesels
    Last Post: 05-04-2009, 10:46 AM
  5. Replaced injector nozzles then problems
    By anhipps in forum GM 6.5 Diesel Engines
    Last Post: 10-07-2008, 04:31 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
