James, I copied this from a the lower part of GM document #1706150.
Elevated Idle
The engine has a cold temperature high
idle feature which elevates the engines
idle speed from 680 to 1200 rpms when outside temperatures are below 32°F (0°C), and the engine coolant temperature is below 150°F (65°C.) This feature enhances heater performance by raising the engine coolant temperature faster.
For pickup models, this feature can be turned off and on using the DIC steering wheel control buttons. If your vehicle is not equipped with the DIC steering wheel control buttons, do the following to turn on this feature:
Turn the ignition to RUN, with the vehicle off.
Press the accelerator pedal to the floor and hold while quickly pressing the brake pedal three times in less than eight seconds.
Release the accelerator pedal and start the engine.
When the engine is started, it will slowly ramp up to the high
idle speed after a delay of a few seconds up to approximately two minutes.
For this method to work properly there must be no throttle or brake pedal faults.
The engine
idle speed will return to normal once the following conditions are met:
Once engine coolant temperature reaches 150°F (65°C).
Air intake temperature reaches 32°F (0°C).
The high
idle speed will be temporarily interrupted and the engine speed will return to normal if any of the following conditions occur:
The brake pedal is applied.
The accelerator pedal is pressed.
The transmission is shifted out of PARK (P) or NEUTRAL (N).
Vehicle speed is detected.
Once these inputs are removed, the engine
idle speed will slowly ramp back up to high
idle after the normal delay, if the conditions for engine coolant temperature and air intake temperature are still met.
