Wiring
There are some duplicates here, but I just copied and pasted everything. Hope this helps...
Here are some more...
and the rest...
Sorry for the mutiple post, I don't know how to post more than 5 pictures at a time.
looking for some help in am a diesel mechanic 50 hours a week on heavy equipment but this truck has me stumped just bought a 98 chevy silverado 3500 not running was told it was a security problem last owner replaced ignition but truck never ran again I have a maxumus 2.0 scan tool but when I hook it up I get an error message that it can't communicate with ecm truck will start for literally 1 sec and shut off I have tested power ato fuel shut down silinode and pulled to confirm function tried 3 different PDMs I am not getting power to fuel pump relay but have it jumped and have confirmed fuel at injection pump need help
Sounds like the theft deterrent (security) system in the ECM is shutting you down.
This thread is from our technical library here on TTS. Hope it helps. See post #2
any ideas why I have no communication with ecm I have been trying to relearn the key. today I'm going to replace security module under Radio and see if it will require learn the key
It's rare, but an ecm can go belly up. I'm not that well versed with these computerized 6.5s. My 93 is mechanical..:)
I do know that bad grounds can wreak havoc.
I know your glad that headache is gone. Glad to see you got it running again
now that I have that solved I'm looking for suggestions on some performance upgrade options truck is a 98 has a built transmission 6 inch lift turning a ten lug convert semi wheels any ideas???
I am new to this and not sure how to start a new thread on here but have seen a lot of good info that I could not find anywhere else I'm sure someone can give me some good ideas
Post some pictures of this bad boy.
The 'Introductions' thread would be a good place, or maybe '6.5 performance' thread. It will help you get noticed and out of this wiring thread.
