Wiring Schematic for 06 LBZ ECM
BoostN
Staff member
Administrator
Tennessee
I need the wiring schematic for the "C1" connector on my 06 LBZ.
which connector is this for? Is C1 and C2 the connector on the controller mounted on the Passenger side valve cover? or the one located down low on the drivers side?
Down low on the driver side. This is the ECM. Top connector is the C1, bottom C2. The bottom must be unplugged before the C1 can be disconnected.
Its a 02/05 Production Date. Does that help?
It's probably a LB7. That list is for a LBZ/LLY ECM. Yours is different. Maybe someone can chine in with a list for your particular ECM.
Yes you will, as it will be totally different. I'm also looking for schematic for you. I'll try to find something.
