Max Attitude
Typical White Person
same as title
same as title
I *think* and there is a distinct possiblity that I am wrong, but the dealer's ability to check CVN numbers began with the 06's. The 07.5+ trucks track and store the last 10 for sure, but IIRC the 06-07's will only give the CVN's of what is currently loaded for them to compare to what the GM database says the last calibrations should be. At least this is what I have read in the past.
I think this is an accurate statement. If the techs actually knew what they were doing with a tech 2, there are steps to follow to be able to see the last 10 reflashes. Unless I miss something, why do you ask? Whats wrong with your motor?
