Nope, but if you don't have one, you REALLY need to be a 6.5 expert. Almost anyone can set timing close enough to run... With a 95, you put the IP within a range and set the computer to handle the signal. If the guy who set yours didn't have the equipment to handle the second part of that, then you need to get the computer (PCM-power train control module) to re-learn the IP position. Engine must be above 180*, etc.
VERY different process from any other truck.
Dealer can can check your timing- ask how much they want. My guy does it for $25, just for readings.
The reason I'm thinking timing is that it was changed during the engine swap. Nothing else will work right if the timing is off.
