DieselDuner
On my Edge Attitude I have the ability to monitor 4 things at once.
On my stock dash I have Tranny Temp, RPM, Speed, Oil Pressure, Engine Temp, Battery, Fuel Level.
I know my speedo is off, but only by 3 and don't feel that I need to waist a spot on watching that.
EGT's, Engine Temp are the 2 most important
So, what do you think are the top 4 most important?
I am thinking about towing here........during my daily drive I don't watch the numbers nearly as much).
I have the ability to monitor:
• Boost
• EGT (exhaust gas temperature)
• Barometric PSI
• Speed MPH
• Engine Coolant Temp
• 1Gear (torque converter lock)
• Intake Air Temp
• Load %
• 2Slip %
• Transmission Temp
• Throttle %
• Turbo Boost PSI
• RPM
• Backdown % (Percent back down due to high EGT)
• Boost
• Barometric PSI
• Speed MPH
• Intake Air Temp
• Load %
• 2Slip %
• Transmission Temp
• Throttle %
• Turbo Boost PSI
• RPM
