Question 1) On this schematic, toward the bottom, there is a box labeled "LP Fuse". Is this a fuse I can add, or is this a fuse already in the truck? If I can add one, then use 15A?
Question 2) I would like to add a switch to power the lift pump, such as a momentary switch. On the schematic, it looks like I can put the switch between either of the #87 terminals and what other wire? My relay socket does not have a terminal for the #87a on Relay 2.
Question 3) There is a Fuseable link toward the left, right off the battery on the schematic. Should I add one of these, or a fuse here, also? If a fuse, use 15A? If fuseable link, what do I ask for at the parts store?
ok, so in response to my question #1, use a fuse in the position where the schematic reads "LP Fuse", correct? By the looks of it, in this position, I'm protecting the lift pump whether in the key on WTS sequence, or in the run mode. The fuse is to protect the LP and there is no protection for the OPS, correct?
I placed a fuse on the wire that goes from the relay to the lift pump.
I also had a fuse in the wire that comes from the power source / battery or hot stud on the back of the under hood fuse box or the hot studs under the cover on the 1994
And a third fuse inline from the glow plug controller to the relays
You do not have to cut any wires. I would not recommend cutting and splicing any wires.
Get a pair of lift pump harness connectors and plug into the ends of the wires it shows cutting.
If I knew how, I would change that schematic so it does not show cutting and splicing any wires.
Thanks. I made up my harness a couple years back and just want to add some protection in the circuit. Mine didn't require cutting any wires on the factory harness.
