I'm supposed to have one on the way. I forgot about Barry. Thanks for the offer. There are at least 2 different parts numbers. One for the older style that had the OS filter and one for the style that had a longer cable to make up for the lack of OS filter. GM 15302629
What I was told:
Originally Posted by Glagulator
The 94 thru 2002 harnesses are all the same, ALL THE SAME, there is no difference. The OS filter was an add-on that was installed after you bought your nice new diesel truck and they could not figure out why they were stalling, dying, surging, etc.
I went through all that with my new 94. All the late 94 -95 eventually had them installed when built, even a few 96 got them even though the problem was fixed
with the OBD2 PCM.
I bought the new harness a few years back for the 99 I have because I was having stalling problems and when I moved the harness it would clear up. When I put the new harness on it did the same thing. Turns out the problem was with the main harness. So I did not use it. I paid over 350.00 for it at the time and was lucky to get it.
FYI - Don't put it back under the manifold, It will work just fine on the pass. side of the intake and will be easy to get to and won't get cooked and oil soaked.
