RC609 (green) Loctite will do the same thing. Same stuff you get with a speedy sleeve kit for a damper pulley. And you don't run the risk of distortion by uneven punch depth.The inner race needs to be snug enough so the bearing turns instead of the race if it's loose then you might have to do some "chinese knurling" take a center punch and put a series of divets around the stub shaft where the race sits and it will tighten it up.
Ok fellas post me a video
Trail and area I recken
Distort the race a bit. I've done both. Just that the green Loctite is made for exactly this purpose. It's referred to in their older literature as "bearing mount".And what would you be distorting, the race? You'd have to have some pretty uneven center punching. I guess it's possible though.
You mean the castle nut that presets the bearing load and has a cotter pin?Any yall know the torque specs on the nut that hold the rotor on?
Yes you are right. Thanks for adding that.:thumbsup:You should check it again after driving it for a bit to make sure it didn't loosen up. No need to redo it just jack it up and check for too much slop.
