Wheel bearing assembly
Duramaxin 41
I'm Confused
Buford, ga
Well, I have already wore one out. The driver side assembly is going to be changed out either by the dealer or myself (depends on how much of a pain in the butt the dealer wants to be). I pretty much have everything I need but the part, does anyone have any helpful hints?
Just make sure you get everything tight when you put it back together. They aren't that hard to change, its all pretty straight forward.
Everything is good now, I wound up getting it done though a dealer, since it was still under warrenty. I guess the next one will be up to me to fix, it will get fix a whole lot faster if I do anyway instead of having to take a day off work and leaving my truck with the dealer for an entire day.
Perfect thats the tip.......have the dealer do it when its sttill under warranty. :beer:
they arent very hard to do yourself.
Remove the wheel.
Compress the brake pads
Remove the two caliper mounting bolts
Hang the caliper by some wire off to the side
Remove the dust cap
Remove the big CV shaft nut
Remove the washers that hold the rotor on and discard as they are not needed. Only there for assembly purposes
Remove the rotor (the biggerst PITA if there is some rust there)
Remove the ABS sped sensor wiring
Remove the 4 bolts that hold the assembly on and it will pop off.
Then put everything back together with the new assembly. The two torque specs I know off hand is 221lb-ft for the caliper bolts and 150 for the cv nut. I believe the 4 assembly bolts need to be torqued around 140lb-ft
its pretty simple, doesnt take but an hour to do.
I got mine from the local auto parts store for $280 with my discount
I just got 2 new bearing / hub assemblies for the LB7. I paid $400.00 for both delivered to my door 2-days later. Just over an hour to change both sides, but its the 3rd set we have changed between the 2 trucks in under 100k.
I think I can still get these for 360.00 a set shipped. They are OEM GM I can go pick them up from him and ship them to you.
If anybody is needing some let me know and I will check my source.
