If it was a Military surplus, they are probably square. The NA engines had square precups and the oil squirters are blocked off, except for 7 & 8. If it was a turbo, then it probably has the diamond precups. If you can pull the oil pan, see if its a standard or high capacity oil pump. If standard, it was probably an NA, high capacity probably turbo. Another tip off me be if it has a shield over the upper timing chain, then probably a NA engine. I wouldn't say any of these will tell you 100% what precups you have, but short of a teardown, probably as close as you can get. One other thing to keep in mind, on the NA engine I had the pistons did not appear to be anodized. Not sure if that makes any real difference, but the replacement pistons were anodized on the piston heads. I guess what I'm saying, if it was an NA, I wouldn't use high boost pressure without the oil squirters and with NA pistons.
