DZZ71
"Living The 6.5 Dream"
Whats the max amount of boost i can push into my truck? I have the ARP head studs is that helps at all.
What are the usual failures from over boosting?
Did you already forget what the original one looked like when you pulled it? LOL!
That was with 18 psi.....
Wow how did I miss that. He has your old truck ?
drive pressure also has a lot to do with engine destruction. the mosre boost you make the more drive pressure there is. good ratio of boost to drive pressure is 1:1. but with some turbos when they start producing more boost the drive pressure goes up more than boost. that is when damage starts happening. im sure the gm x series of trubos when making big boost have higher boost numbers than say a hx35 or another turbo with a bigger turbine
Glad to see you're paying attention Kenny....):h
BTW - thanks for the b'day card....LOL!
