Did the removal of the fitting cause the damage? You were lucky, most times they break off.
i am going to. i will also mount my FFM on the fender. using aluminum tubing instead of rubber the whole route. i will get a prefilter using one of these:This may be a strange question but is there any reason to try to move the wire loom that lies in the engine valley up higher? I am talking about the loom that carries all the wires along the valley from the firewall forward to the IP.
looks like you decided not to run the IP harness on the outside. i removed mine from the loom, separated them and now they run to each component. doesn't look real clean right now but i will get some more loom to cover them....
View attachment 32316.......
I just charged them. But I may throw it on there anyway while I button up some stuff.
I have not been able to find clear line. I asked the local parts guys. Where do you get it?
I am going to attempt to finish it up today. I read somewhere about putting 2 stroke oil in the ffm for the first spinning of the IP. Is this recommended?
