scottm
What changed about the ecm starting in 96? Did it go to OBD 2? How much harder is it to re program the newer ones? I ask because the newer the engine, the better for emissions-legal swapping.
Thanks! Once it is working, can you put on a manual pump and have the ecm continue to run the trans? (for off road use only of course)
:stupid:
Burning Oil sells an aftermarket trans controler, IIRC. Check out his site.
