Odlaw
Redneck
Disclaimer for the moderators; I apologize if this is not in the correct area of the forums. I spent ten minutes trying to decide where is should go without getting my hand slapped :hihi: I think this problem is something in the interior (but I could be wrong) - might be suspension - so feel free to move it there if needed.
I get this weird, fast, thumping noise (almost like a vibration) when I run over a rough surface...like the lime rock on my long driveway...... When sitting still, I can hook the bottom side of the brake pedal with my toe and pop it up and down and that's the sound I'm hearing.....but it's not coming from the brake pedal because I can hold up on the pedal (while driving) and the same sounding noise is still there...it sounds like it's coming from the firewall, under/behind the instrument cluster(maybe steering column? ). There is a block with a couple of large electrical plugs on it (directly under the fuse panel on the driver end of the dash) - it was flopping around in the bracket. I shoved some old bike inner tube in the bracket and fixed that problem.
Both front shocks appear to be leaking a little and even though I would like to blame this sound on the shocks, when I roll the windows down you cannot hear the thumping outside.
Anybody else having this problem on a silverado classic?
I'm open to suggestions here...
Thanks
Smitty
Thanks
Smitty
