DieselSlug
I am trying to get to the bottom of an on-going issue I've had for several years with my 05 Yukon XL. It is mostly pertaining to power steering effort while the vehicle is moving very slow or stationary. Specifically navigating parking spaces, parallel parking, at idle, etc. I have very little if any support from the power steering system and it feels mostly manual until I can get the vehicle rolling at least a couple MPH. This seems worse while on the brakes as well but I do also notice it while off the brakes as the Yukon is equipped with hydroboost.
I replaced the initial steering pump when I got the vehicle about 4 years ago (2022) due to a leaky rotted out reservoir. I purchased a reman Cardone on Rock Auto which was noisy as hell right from the get-go. I ended up replacing the Cardone with a Napa remanufactured (still a POS Cardone I later find out) unit in 2023 which started the hard steering issues. I ran this until April 2025 where I purchased a "new" Edelmann Pump off RockAuto hoping to cure the issues. With this pump since install I have still had issues with the steering at very slow speeds. Contemplating if it it truly pump issues or maybe Hydroboost issues? I have replaced the hydroboost due to leaky seals back in 2022 with another reman (you guessed it, POS Cardone). My brakes seem fine, but could this be causing me an issue? I've also watched some videos of people boosting pressure of the pump to a max of 1,400 psi to help with larger tires. I still have the old Napa unit in a box that I might take apart for inspections
