Deere Freek
Recruit
What are the pro's and cons of each? I'm looking to get one or the other. The 2 i'm looking into is heath's mpg max water/meth kit and Kennedy's ic. Looking to make a purchase in the next couple weeks.
i like that answer. i have a w/m by devilsown on the way as it is somewhere between oklahoma and here. another plus is you can run water/methanol at 10% meth ratio which is good for more ponies as well as cooling the intake air. rather than ask the benefits of either you should say what your intent is. as an example, my reasoning for w/m is i tow rarely, the load i carry is no where near what a stock truck can handle. the climate here rarely hits anything near 95f. see location on my posts. helps us 2 help u. Edwell, with an intercooler you never have a tank to fill. With water meth, there is no rerouting turbine outlet lines. With an intercooler you dont have to come up with a tank to put somewhere. With water meth you dont need to find a place to put an intercooler.
Check this thread out. It explains each pretty well.
http://www.dieseltowingresource.com/showthread.php?t=2451&highlight=intercooler
Never mind! I see RC beat me to it. I guess I should read more!
i do offroad which is one of the main reasons that would scare me to use an intercooler. I do moderate towing but typicly it's under 6k.
i just finished the install today. ran into some issues. problem was the tap-in for the map sensor not being connected when i thought it was. as for difference. i only drove two miles so far but sounds different as in more turbo whistle. as for seat of the pants. well i mounted it under the truck below where i sit so when power comes on it tickles my butt. here is a link to the install. http://www.alcohol-injection.com/forum/install-pics/install-pics-6-5-gmc-diesel-1653.html EdWhat noticable diffrences in power/egt's did you get after the install?
Any results with using meth yet Ed??
(Ed's a meth-head lol)
Are those telescoping mirrors? Can you see past your load?
Why can't you ATA and W/M?
they are clip on mirrors. i can barely see the trailer when towing. keep in mind the camper is X feet wide and the trailer is quite a bit slimmer. even with the extensions on BOTH mirrors i can only see the trailer out of the drivers mirror unless i round a corner then can see the passenger side as well. never had a law problem there as i can see way back on both sides just can't always see the trailer, and there is nothing wrong with going wmi and ata, just have the wmi near the intake. if you plumb in before the ata you risk water pooling at the bottom of it. EdAre those telescoping mirrors? Can you see past your load?
