Water in fuel sensor & fuel heater in the fuel filter housing ?
Crankme69
Illinois the Corruption Capitol of USA
Questions about the filter manager on my 95...?
Is the fuel heater in the filter manager the same element as the water in fuel sensor…are they one in the same?
I so far have unplugged the 2 wire connector directly located behind the fuel manager that appears to have 2 wires running to the bottom section of the filter housing, best I can see anyways without removing the filter housing.
Is there another plug for the fuel heater or does this 2 wire plug supply power to both the water in fuel sensor & the fuel heater in the fuel manager or like I asked above does the one element do both?
TIA :thumbsup:
On the side of the housing near the bottom is the water in fuel sensor. It is held there by 2 screws and has 3 wires to it. The heater as you know is at the bottom with 2 wires.
Excellent thanks so right now I have the 2 wire connector unplugged, that must be for the heater, correct?
Looked online at rockauto, no replacement heater element to be found...maybe I am not looking in the correct section?
The GM part number listed here does not come up with anything?
The GM part number the dealer supplied me with for the fuel heater is 12511964, GM dealer part retail $199.44.
Stanadyn has no cross reference for the part number, the gent I talked with at the local dealer is sending stanadyn an email & will call me back.
This may very well end up coming from the junkyard if i can not find one used from a member...?
ssdieselsupply (TD Edit, direct hotlink to non site vendor edited out we don't provide free adverts to non site sponsors that compete with existing sponsors with hot links to their site, not a big issue this note just as an FYI to all)
Not much better at 189.99.
Sounds like you're not even gonna get kissed.....
Yea I'm going to pull the manager off this weekend see if there is any bare wires before I shell out that kind of dough.
gmpartsgiant dot com GM Part 12511964
Genuine GM HEATER,FU
Retail Price: $199.44 Your Price: $139.26
I thought the OEM FFM was a Racor unit? that may explain why stanadyne wasnt much help. I misunderstand stuff frequently, so please ignore this statement if I am wrong.
Nice, Stanadyne is less than half the price as online GM parts.
while youre in that FFM, see if there is a corkscrew piece inside the central fuel input shaft. The heater slides up into this shaft into the corkscrew thing. If the screw thing is there just push/pull it out as its a restriction for fuel pressure.
I imagine the purpose of the corkscrew thing is like the corkscrew in a gas hot water heater to put the hot gas near the water tank side instead of the hottest gas going straight up the center. In other words this is transferring more heat from the heater to the fuel and making sure fuel flow past it is all evenly heated and gel wax flakes completely melted.
