Golds was correct, your code 78 is "boost out of range" which could be either high or low. (in your case, 2 psi is 'way low). Without a chip or reflash, you cannot run sustained boost over about 11-12 psi without coding. I'd aim for a sustained boost around 8-9 psi. Crank it up a bit and see what happens.
It appears you know not to blow things up, so here's the diagram for the boost-fooler circuit. I doubt that your GMTDscan will work right after you install this, because it 'fools' the sensor that GMTDscan uses to read manifold absolute pressure.
So, you'll need to buy and install a boost gauge.
Have fun!
Cool... kind of like a peg in an old speedometer... when you're on the peg, you know you're going faster than that, but you don't know how much?
