Will
Boobies make me happy
Does anyone have plans or a place that I can buy the parts to make an adjustable pulling hitch? I seem to recall a post some where on the board saying a member bought the ring as well as the channel with the holes in it at a camper parts store but I'm not 100 percent correct.
I would also like to build some rear suspension stops as well. I have a plan in my head. Take a piece of flat stock say 3/16 or 1/4 thick x the highth of the frame. Then weld a piece of square tubing to that plate. Bolt the plate to the frame. Find another piece of tubing that will slide inside that tubing. Drill holes for a pin to slide through to make it adjustable. Sound like it will work? How big of tubing should I use? 2x2? Open to suggestions here.
