juddspaintballs
my balls are painted!
I'm in the midst of installing Leroy's Walbro FRC-10 pump and pre-filter setup. Everything is plumbed up in place and wired properly (I actually used a relay to give the pump plenty of amperage). I cranked the engine and it fired up, but shut off when it burned the fuel in the fuel filter manager. I did not fill the pre-filter like I realize now that I probably should have. No fuel got sucked from the tank into the pre-filter.
If I go get a little bit of diesel and fill the filter, refill the FFM (and maybe let some run backwards through the line until it comes out at the pre-filter housing), I should be able to start it up again. Will the pump suck fuel from the tank if the pre-filter is filled or do I need to do some sort of back flush of fuel through the system until the entire line is full of fuel all the way back into the tank?
